I need your measurements
http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=47452
Author:  Chris Ensor [ Tue Mar 15, 2016 10:10 am ]
Post subject:  I need your measurements
I am needing to collect some measurements. I am needing to know the hole spacing on different laminate trimmers and mini-routers bases(no full sized routers needed). What do you think OLF, can you help me out?
Please denote the brand and model as well as the measurement(s) for your spacing. Thanks.
Author:  Bri [ Tue Mar 15, 2016 10:38 am ]
Post subject:  Re: I need your measurements
Hi Chris, what specs are you wanting?
I have 4 or 5 different ones I could measure.
Author:  Chris Ensor [ Tue Mar 15, 2016 11:41 am ]
I am needing the hole spacing of the screws that hold the plastic plate to the base of the trimmer/router.
Author:  Pat Foster [ Tue Mar 15, 2016 11:44 am ]
Perhaps you could list what you already have so there's no duplication.
I have a Porter Cable 3102 and 7301, and a Makita 3709.
Author:  Pwoolson [ Tue Mar 15, 2016 2:48 pm ]
I've got bosch colt base plate plans drawn up in cad if you want them.
Author:  Alex Kleon [ Tue Mar 15, 2016 3:13 pm ]
Rigid laminate trimmer model #R2401. Hole spacing measures at 2 3/16" or 55mm, square layout.
Alex
Author:  Bri [ Tue Mar 15, 2016 5:55 pm ]
Bosch Colt pr10 3" x 2.72"
Dewalt dwp 611 2.42" square, but there are 4 more holes asymetrically placed. all holes are at 1.73" radius c-c from the center of the collet.
I can measure the PC when I get home.
Author:  Chris Ensor [ Tue Mar 15, 2016 9:29 pm ]
Thanks everybody. Keep them coming. I need as many as possible.
Author:  Colin North [ Wed Mar 16, 2016 3:42 pm ]
Makita RT0700C
I make it 54 mm x 45 mm, long side towards the catch.
Author:  Bri [ Wed Mar 16, 2016 9:42 pm ]
PC7301
As you can see, multiple holes
The plastic base mounts to the 3 lower holes in the pic.
2-11/32" across l-r
-21/32 from l or right to the lower
On the boss with the 2 holes the upper one is the bottom end of the depth adjuster.
The other on that boss and the one to the right are 1" apart.
The upper 2 are 2-1/16" apart.
Author:  Mike2E [ Sat Mar 19, 2016 12:17 am ]
Colin North wrote:
Makita RT0700C
My Makita RTO700C has a trapezoid base pattern , one side 54 mm and the side parallel to this 56 mm, each of these spaced by 45 mm.
From collet centre to holes 56 mm apart the radius is 38.25 mm.
From collet centre to the 45 mm spaced holes the radius is 33 mm
Rebel tools REB500T has square base hole pattern 58 mm
